help build my motor
Old Feb 3, 2010 | 01:42 PM
silverbullet-dodgeram's Avatar
Default help build my motor
well as yall no i blew my motor so i wanna do a cheap build. im gonna bore the motor and put new pistons in the motor. is there any thing else i have to do when i do this and what some stuff i should do while im in the motor this deep
Old Feb 3, 2010 | 01:58 PM
nopower318's Avatar
nopower318
Define "cheap" because rebuilding a motor is gunna cost a good bit of $$$$
Old Feb 3, 2010 | 02:05 PM
yakkier's Avatar
yakkier
Nothing cheap at all about breaking appart an engine, and if you put it back togeather with out doing any major overhaul, you would have wasted your time and it'd be nothing but a **** tease at that point
Old Feb 3, 2010 | 02:21 PM
what you guys think about this?
http://www.summitracing.com/parts/FE...-300/?rtype=10
Old Feb 3, 2010 | 02:27 PM
Twisted Metal's Avatar
Twisted Metal
Wow,what a loaded statement/question. Without a long drawn out explaination of how or what I would do, I think I will skip it. The words "cheap" and "rebuild" don't belong in the same sentence. If you want cheap, pull a junkyard engine and drop it in. That is probably the cheapest way to go. Call me a pesimist, or the fact I never half *** anything. but this sounds like a recipe for disaster.
and to the OP, that rebuild kit is for 1974-1978 LA Blocks. Not the Magnum. Not 100% sure if it makes a difference.
Old Feb 3, 2010 | 02:34 PM
Gerehead8's Avatar
Gerehead8
Originally Posted by silverbullet-dodgeram
That kit won't work since it is for an LA motor. You must get a kit specific for the Magnum. Do not order the kit until you know what you are doing with the motor. The kits vary on how much you bore the motor, if the crank needs to get ground, if you need line bore, ect.
Old Feb 3, 2010 | 03:39 PM
does any one no where to get a piston rebuild kit like the one above for this motor
Old Feb 3, 2010 | 04:29 PM
95RAM360's Avatar
95RAM360
id replace heads, camshaft, possibly crankshaft, have the entire motor torn apart and cleaned, new oil pump/screen, RR's, push rods, and that should be enough to get you going along with the bore, pistons etc.
Old Feb 3, 2010 | 04:51 PM
Gerehead8's Avatar
Gerehead8
Same place you found the last one.
http://www.summitracing.com/search/m...?Ns=Rank%7cAsc
Old Feb 3, 2010 | 05:39 PM
iwhitne's Avatar
iwhitne
I agree .. not such thing as a "cheap" rebuild...
bore it out.. all new pistons,connecting rods,cam shaft,rr,push rods, heads, and crankshaft.. allong with plugs, wires, rotor, dist cap, oil pump, timing chain, water pump, and all new gaskets ect...
like stated above.. get a cheap junk yard motor with low mileage and swap it in.. I've seen them as cheap a $850 with less than 50,000 miles
