camshaft
Old Feb 3, 2010 | 03:47 PM
2000_ram_1500's Avatar
2000_ram_1500
Default camshaft
Just wondering if anyone is running a Xtreme Energy XR258HR-12 Hydraulic Roller Camshaft Only Lift: .480''/.480'' Duration: 258°/264° RPM Range: 700-4800. If so what kind of gains did you see I have one of these sitting on my shelf and i'm debating on installing it or not.
I have a 2000 ram 1500 2 wheel drive with a 5.2L
Old Feb 6, 2010 | 10:38 PM
2000_ram_1500
Default Is anyone using this camshaft.
I have a Comp cams XTREME ENERGY XR258 Hydraulic Roller Tappet, Advertised Duration 258/264, Lift .480/.480,And was wondering if someone out there is running this cam in there truck. I would like to hear some feedback on what kind of gains I will see.
Old Feb 7, 2010 | 07:41 AM
aim4squirrels's Avatar
aim4squirrels
That cam will give you a nice little boost, I'd guesstimate about 40 HP at the crank and probably a bit better off the line. If you get the idea to run 1.7 rockers with it, double check the piston to valve clearance.
Old Feb 7, 2010 | 07:51 AM
360mag45's Avatar
360mag45
hey wht kinda stuff do you need to have to replace a camshaft any specil tools. and wht all do you need to do to replace it
Old Feb 7, 2010 | 03:50 PM
dodgeram07's Avatar
dodgeram07
it a good idea to get new lifters,, and most likey you will damage your cam bearing and need to replace that and do that you will need a tool,,, also a new t-chain
Old Feb 7, 2010 | 04:37 PM
360mag45's Avatar
360mag45
damn thought i might be a cool and kinda cheap way to make power and make the truck lope.(when i say cheap i mean that the parts are not to expnive just lots of work)
Old Feb 7, 2010 | 04:42 PM
dodgeram07's Avatar
dodgeram07
ya plus if you get a out of the close to stock rang(lift and Duration) and the lift part you will need new valve spring and on the Duration part a new tune,,$$$$$$$$$$$$$$
