need help 02 dodge cummins computers
Old Feb 4, 2010 | 03:09 AM
rambeast440's Avatar
rambeast440
Default need help 02 dodge cummins computers
my truck is a 2002 dodge 2500 cummins auto tranny
I am getting code
p0606 ecm/pcm processor
p0237 turbo boost sensor A curcuit low
p0121 throttle position sensor A curcuit low input
p0117 engine coolant temp curcuit low input
p0112 intake air temp sensor 1 curcuit low input
all of these codes showed up at the same time while driving home from work The truck will still start and idle but it has no power and the throttle won't rev the engine up. I took it to dodge to diagnose they said it needed new pcm, throttle position sensor and alternator. I changed the throttle sensor and found them a used pcm with same part number throttle sensor did nothing I checked the voltage that the apps was putting out it seems to be fine from idle to wot they tryed to flash the used pcm but said it did nothing.
Then they said it needs a new Ecm, I replaced it and it is still throwing all the same codes wasting alot of money and don't know which way to go maybe I need a new pcm but I have already spent $2000 and have fixed nothing if anyone has any ideas please let me know I can provide more information if needed I have a used spare pcm but i don't know if they can reprogam it to my vin may have to go new but want to make sure before spending anymore
Thanks Matt
Old Feb 4, 2010 | 08:13 AM
torp74's Avatar
torp74
Sorry I can't help ya. I haven't seen a whole lot of Cummins trucks on this board so I would recommend you check out one of the several Cummins specific boards out there. Just google "Cummins forum", there are several out there.
