Adding gauges, a few questions
Old Feb 5, 2010 | 07:40 PM
  #31
jamestheron08's Avatar
jamestheron08
do you know the size or part number for that? there asking for the hose size
Old Feb 5, 2010 | 07:51 PM
  #32
Miami_Son's Avatar
Miami_Son
It's your truck, go measure it. I have a V10, so it isn't the same as yours.
Old Feb 5, 2010 | 08:06 PM
  #33
jamestheron08
i have a v10 aswell thats why i asked thanks anyway
Old Feb 5, 2010 | 08:13 PM
  #34
Miami_Son's Avatar
Miami_Son
Well, if you took a moment to fill out your profile info I would have known that. In any case, if you have questions about their products I suggest you contact Glow Shift as they can better answer them. I don't have the hose adapter, I just know they offer it. Good luck.
Old Feb 5, 2010 | 09:45 PM
  #35
codyselcamino's Avatar
codyselcamino
Originally Posted by PurplDodge
I would get some full sweep gauges. Although they wont match the factory cluster (who cares about that anyway!), they will be more accurate. I wish I had that mindset when I bought my transmission temperature gauge!
I have an Autometer Sport Comp II (one of the closest look to the factory gauges) short sweep transmission temperature gauge. And I have the sensor in the front servo port in the transmission (let the debate begin!). Really nice gauge.
i got VDO cockpit guages, they match almost 100% even the green light,
its a poor picture but this is my set up, the top it outside air temp (i dont have the overhead computer) and the bottom is trans temp, mounted in the servo port, if you mount it there and have a pretty good sized cooler on the front dont expect to see temps over 150 around 40 degrees out
Old Feb 6, 2010 | 06:08 AM
  #36
BlueBeast2's Avatar
BlueBeast2
I agree a WB on a stock engine is overkill. Rick your crazy lol.
As for the stock water temp gauge. My e fan set up has a sensor in the intake. It trips the fans when the water is 180. It's damn near dead on when they trip
Old Apr 9, 2010 | 09:58 AM
  #37
mnewbolds's Avatar
mnewbolds
I found a sunpro oil/water temp gauge for real cheap. I know I get what I pay for but will it work for trans. temp? It has a few fittings in the package, not sure where they would tie into. I don't have the money to afford the Autometer or Glow shift. Just need to have to keep track of the temp somehow. Any ideas?
Old Apr 9, 2010 | 10:13 AM
  #38
95RAM360's Avatar
95RAM360
ok may be a dumb question, but is there a way to wire in a trans temp guage without drilling anything? can i just tap into a wire?
Old Apr 9, 2010 | 10:18 AM
  #39
mnewbolds's Avatar
mnewbolds
With an electronic temp gauge I would think that it reads off of resistance. If you have an indicator light for your trans temp, it should wire into that. Don't take my word for it, but that's how I would think it works. I'm going for a mechanical but cannot think of anywhere to tap into, I really do not want to drill holes.
Old Apr 9, 2010 | 10:22 AM
  #40
95RAM360's Avatar
95RAM360
i asked about that before...about wiring into the dummy light since it DOES tell the temp of the tranny since it goes one when hot.....but all my responses were "i dont know if that will work"
i need one...i overheated my tranny once offroading.....i havent been offroading since, im scared, so i want a guage...i guess if i have to drill a hole in the pan to go back into the trails, then thats what im going to do....sucks becaue i just did a tranny flush....60 bucks in fluid.....dont want to have to drop the pan again....
