Bad Fit Steel Roll Pan
Old Feb 4, 2010 | 07:17 PM
zierbox's Avatar
zierbox
Default Bad Fit Steel Roll Pan
I have a 96 ram
I ordered a steel roll pan with Toyota supra tail lights from FBI Rides
The tail light openings were all off (lights fit like crap)
Then the clearance for the tail gate is all wrong (totally rubs can’t open the tail gate)
I had to majorly modify my tail gate to allow for open clearance
Anyone else have this situation
Old Feb 4, 2010 | 07:25 PM
PurplDodge's Avatar
PurplDodge
That is gonna look sweet when done! Are you gonna relocate the handle on the inside and take off the diamondplate?
Old Feb 4, 2010 | 08:05 PM
Miami_Son's Avatar
Miami_Son
How do you get to your trailer hitch, now?
Old Feb 4, 2010 | 08:08 PM
yakkier's Avatar
yakkier
Really ? Supra lights ? .... cut the lip off the damn tailgate otherwise dont use your tailgate and get a net instead
Old Feb 4, 2010 | 08:14 PM
PurplDodge's Avatar
PurplDodge
On some of them have a cut-out where the license plate is and the plate is on a spring hinge, so the hitch is concealed.
I just had a cool idea. Forget about the Supra headlights, not so much Dodgey... Replace them with some taillights from a 68-70 Dodge Charger. That would look much cooler.
Old Feb 4, 2010 | 08:18 PM
Miami_Son's Avatar
Miami_Son
I know that, but I see no such provision in this case. Also, if you look at the hitch in the 1st pic, it is weird. The receiver part is mounted on top of the crossmember. If it were mounted below then the hitch stick would go in under the roll pan as it would be below the body line. Strange.
Old Feb 4, 2010 | 08:20 PM
rumble_truck's Avatar
rumble_truck
At first i wondered how you were gonna get supra lights to fit in the stock location and how welding a patch in the old corner lights would help any.. then I realized what you had done..
This gonna be a show truck or something?
Old Feb 4, 2010 | 08:24 PM
PurplDodge's Avatar
PurplDodge
Do you see the faint lines shaped like a box. Maybe there is a provision and they just dont ship then with it cut out incase you dont have a hidden hitch.
Old Feb 4, 2010 | 08:32 PM
WaynesWorld's Avatar
WaynesWorld
mad fab skills on the stock tailight fillers. The body line is right on!
