Is the 360 an interference engine?
Old Feb 5, 2010 | 10:05 PM
blong4life's Avatar
blong4life
Originally Posted by dhvaughan
i'm not following the story here - what the hell happened ?
did you replace the cam ?
or just the timing chain ?
the cam and crank are slotted for keys, and there's only two? ways it can go on, right? the right way and one wrong way, where the crank dot is up but the cam dot is also up (instead of down) ?
fess up. what happened ?
have you put everything right and rechecked for compression ? i can't believe all eight cylinders have zero compression. that doesn't seem right.
Replaced the timing chain. Well, I went ahead bought a top gasket set, and 16 new shiny valves .
Dads going to start stripping out the stuff tommorrow; i have to work.
Old Feb 7, 2010 | 11:53 PM
blong4life's Avatar
blong4life
So I did it, 8 bent intake valves and 8 bent pushrods. No piston damage and while having the motor pulled apart it looks pretty clean, which is always a good thing. Going to start putting it together tommorrow night.
