im about to go get my exhaust done cowboy cut out the back, what i wanna know is if i take my cats off will my mileage decrease? right now its straight piped from cats back....and will it hurt my truck? ima search for a similar post as well dont flame me tellin me to go look please need this help fast...its an 01 ram 1500 5.9lgas.
ok well im readin on here now that if i take my cat off it will mess my truck up? if i take it off and i put it on before inspection will i be ok? and will takin the cat off mess the truck up
it MAY throw a check engine light, but theres tricks around that....if you get inspections, you might wanna gut the shell and weld it around your pipes for looks or get a high flow cat
ok badass ill get a vid up of it and see if you guys like it at all...and ill join that 2wd thread as well...ye its lifted bud proudly a 2wd=] if i had 4wd i wuldnt have a running truck=\
