lashing valves W/ retarded cam
Old Feb 8, 2010 | 04:04 PM
USAF90's Avatar
USAF90
Exclamation lashing valves W/ retarded cam
my cam is retarded 4*, do i have to lash the valves at 4* before TDC???
cant find this answer anywhere
Old Feb 8, 2010 | 10:47 PM
dodgeram07's Avatar
dodgeram07
stock rocker are not adjustable
are you using atfer market one?
Old Feb 8, 2010 | 11:38 PM
USAF90's Avatar
USAF90
naw man i figured it out.. thanx tho
Old Feb 8, 2010 | 11:43 PM
dodgeram07's Avatar
dodgeram07
ok keep on truckin i want pics when the motor all put back together
Old Feb 9, 2010 | 12:01 AM
USAF90's Avatar
USAF90
aight ill make sure to get that picture up
quick question tho.
5.9l 1996 ram, motor is turning over real good, wont fire...
checked/tested plug wires, coil, brand new battery, fuel pump is fine, fuel gets to the rail, all connections are connected, ign. rotor/cap good, plug gap is good..
the only thing is i dnt think im gettin spark, that leaves me coil harness, and grounds.. anything im forgettin?? maybe a sensor??
Old Feb 9, 2010 | 12:02 AM
helms's Avatar
helms
crank sensor?
Old Feb 9, 2010 | 12:15 AM
USAF90's Avatar
USAF90
i have no idea.. i had this problem BEFORE i rebuilt the motor, thinkin while rebuilding i would find something.. fixed a few oil/coolant leaks and made a few mods but d*mn things still aint firing..
Old Feb 9, 2010 | 01:41 AM
BlueBeast2's Avatar
BlueBeast2
I wouldn't have bought a retarded cam. That just sounds bad from the start
Is your timing right? I had the same problem when I tried firing up mine after the rebuild
Old Feb 9, 2010 | 01:46 AM
1fast2liter's Avatar
1fast2liter
kinda what i was thinking.. hell the only thing retarded in my truck is me thats all i need...
by the way my momy bought me grape windex and now my windows taste like purple!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!
Old Feb 9, 2010 | 01:51 AM
BlueBeast2's Avatar
BlueBeast2
Purple as in https://dodgeforum.com/forum/members...urpldodge.html ?
I don't wanna know how you know what he tastes like
