What I've been up to?
Old Feb 10, 2010 | 12:07 AM
  #21
BlueBeast2's Avatar
BlueBeast2
They are like 10ft long. The front tires were almost on the gate so it was damn close to being in the truck. I think runners would do the trick. I really want the metal ramps but so far the ones I found are only like 7ft. That would be an insane angle
Old Feb 10, 2010 | 12:11 AM
  #22
yakkier's Avatar
yakkier
make some man, if you can get ahold of a welder all you need is a couple pieces of framing from an old pickup and some angle iron, couldn be more than 50 bucks
Old Feb 10, 2010 | 12:16 AM
  #23
BlueBeast2's Avatar
BlueBeast2
I have 2 welders but can't weld to save my ***. I have some probably 1" square tubing. I would think though you buy some and they fail you can go back on someone. If I build them and they fall apart I'm on my own
Old Feb 10, 2010 | 12:20 AM
  #24
yakkier's Avatar
yakkier
promotes good workman ship learn by trial an error my friend, trust me i got a ****ton of scars to back all the stuff i know
Old Feb 10, 2010 | 12:21 AM
  #25
crazzywolfie's Avatar
crazzywolfie
you could try building some ramps like this with some square tubing. you would just have to make them longer
Old Feb 10, 2010 | 12:29 AM
  #26
yakkier's Avatar
yakkier
thats exactly what i was talking about, ty for findin a pic of them
Old Feb 10, 2010 | 12:32 AM
  #27
Weldor's Avatar
Weldor
This may sound stupid because I don't ride a quad or snowmoblie but what about just using two ladders? Or would the load be to heavey
Old Feb 10, 2010 | 12:39 AM
  #28
crazzywolfie
lol. 2 ladders might work. it is kind of hard to find 2 ladders that are the same size for a rellatively cheap.
Old Feb 10, 2010 | 12:40 AM
  #29
yakkier's Avatar
yakkier
the flyside and ground side of the ladder's would hold it fine, but the rungs would break inhalf,
Old Feb 10, 2010 | 01:37 AM
  #30
Dodge4lyfe's Avatar
Dodge4lyfe
I got one of those build a ramp kits and had the same problem with the tires sliding...I found some Diamond Plate screen...it's what they use for flooring in factory balconies...and screwed it into my 2x6 ramps. It provides enough traction to allow you to get traction with a quad yet my sled carbides won't catch on it. the diamond shaped holes also allow any snow on the tires to fall into the grating so you still have traction..
Actually, any kind of metal grating should work granted the holes aren't too large...
