sounds like marbles in the motor
Old Feb 12, 2010 | 11:00 PM
bigtigga's Avatar
bigtigga
Unhappy sounds like marbles in the motor
i have a 95 ram 1500 with a 5.9 i was driving to work and i went to turn a cornor and my truck shut off and would not start back up that was tuesday so i went back to start it up today and fired up and it sounds like there is marbels in it so i turned it off quick and i just replace rear main seal oil pump water pump and timing chain and i just want to find out what it is all help would be great and ideas where to start. it sound like something is hitting metal and i need to get it fixed but i dont know what it is this truck is starting to get me in a bad mood please help me out also you think it was the timing chain that broke could that cause it to sound like that i am gonna remove the cover and check on the safe side thanks
Old Feb 12, 2010 | 11:07 PM
xxxcowxboyxxx's Avatar
xxxcowxboyxxx
well if the T chain broke i doubt it would have started for ya as it would be all out of time. how about a defective water pump. maybe a fin broke off and its bouncing around.
Old Feb 12, 2010 | 11:08 PM
bigtigga's Avatar
bigtigga
i will check when i remove it but i just wanna get it fixed
Old Feb 12, 2010 | 11:14 PM
xxxcowxboyxxx
maybe pop off your valve covers too (as much of a pain in the *** that is) and make sure you dont have a broken valve spring
Old Feb 12, 2010 | 11:17 PM
blackskyracing's Avatar
blackskyracing
Drain the oil... That`s a cheap way to see if there`s any troubles in the bottom. But it`s probably in the top end if there`s a lot of sharp rapping...
Old Feb 12, 2010 | 11:27 PM
cmckenna's Avatar
cmckenna
I had the same noise after changing my oil pump and all it was (thanks to someone here) was the sheet metal plate that covers the bell housing area / flywheel. I had to re-form it as it was bent and hitting the flywheel plate bolts. Sounds like a hollow, tons of noise coming from the oil / crank area but, from inside truck, yeah, startling because, from that perspective, one can't tell where it's coming from.
Now, as for the stalling around corners- check your EVAP canister - it may be plugged and, for some reason, I recall reading many times about this occurring due to a bad canister. R&R it anyway if it's old.
CM
Old Feb 12, 2010 | 11:29 PM
xxxcowxboyxxx
+1 on CM's advice
Old Feb 12, 2010 | 11:54 PM
Ram_Me's Avatar
Ram_Me
Remember; do some checking before you spend any money. Pull the spark plugs and see if they're all together or not. That would be a good sign for if you have anything inside of your cylinders.
Do you have any engine codes?
Old Feb 13, 2010 | 01:01 AM
bigtigga's Avatar
bigtigga
no i dont have any codes and i am gonna check the plugs and the plate by the flywheel also the valve springs i wish i knew what was wrong put to all that replyed to this i greatly thank all of you
Old Feb 13, 2010 | 01:10 AM
xray99's Avatar
xray99
Little you can do without digging into it a bit, eliminating possibilities.
Good luck, update when able.
