The front d60 axle will bolt right up no mods needed, but the rear d70 has 3'' wide spring perches as the 9.25 has 2.5'' wide perches. If you have good welding skills all you would have to do is cut the old perches off and weld new one's on. And I can't remember what it is but you have to do something with the rear drive shaft. For that price it's well worth it.
