door flapping in the wind
Old Feb 14, 2010 | 08:20 AM
360mag45's Avatar
360mag45
Default door flapping in the wind
so the other day i was heading up 83 to the sportsmans show i was going along at a good click speedo said 75mph gps said 83mph. and when ever i would hit some head wind my door would start flaping it stayed latched and all but kinda was scary and annoying cause of the sound anyone else have this promblem. do i just need some new seals
Old Feb 14, 2010 | 08:56 AM
dhvaughan's Avatar
dhvaughan
i don't think the door should flap.
if your door doesn't feel like it latches tight, try adjusting the strike pin in a little tighter. mark it before you move it so you can return it to the original location if need be.
Old Feb 14, 2010 | 09:01 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Originally Posted by 360mag45
so the other day i was heading up 83 to the sportsmans show i was going along at a good click speedo said 75mph gps said 83mph. and when ever i would hit some head wind my door would start flaping it stayed latched and all but kinda was scary and annoying cause of the sound anyone else have this problem. do i just need some new seals
I have the *EXACT* same issue with my truck. In strong winds, the door seems to move in and out along the hinge side. I wouldn't say that it "flaps"; it's more like a person's chest when breathing -- rise and fall.
I attributed it to the worn bushing on the hinge pin. Just a minor amount of movement there will yield a great amount of movement on the door as a whole. Does your driver's door yield a horrid screeching noise when opened/closed?
Old Feb 14, 2010 | 01:17 PM
360mag45's Avatar
360mag45
no didn't make a skreaching sound and it seems like the top of the door is whats moving i well check into tighting up that stuff but it is latched.
Old Feb 14, 2010 | 01:25 PM
Miami_Son's Avatar
Miami_Son
It can be latched and still do this. A worn or compressed door seal, worn or misaligned hinge, or a misaligned striker and latch plate could all cause this.
Old Feb 14, 2010 | 01:30 PM
yakkier's Avatar
yakkier
my driverside does it around 75 - 80 when im going against the wind.
Old Feb 14, 2010 | 01:49 PM
MrRuckuss's Avatar
MrRuckuss
speaking of door seals i need some
Old Feb 14, 2010 | 02:04 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Yes, it is the leading edge of the door, which would be the angled part of the door, forward of the exterior rear view mirror.
I learned quickly not to rest my arm on the door armrest and the prop my fingers along where the door frame meets the A-pillar. One moment, I'm gingerly pinching the rubber seal, and the next moment, *MY FINGERS* are getting pinched!
Please report if you've been able to correct the problem, and what actions were taken.
Old Feb 14, 2010 | 03:20 PM
360mag45's Avatar
360mag45
my door sags so that might be the problem i see wht i can do and i well report back
Old Feb 14, 2010 | 04:40 PM
iwhitne's Avatar
iwhitne
haha.. mine does the same thing...
