I have a hunch on why I get such bad MPG
Doesnt look all that worn out. The one thats in my truck now looks worse than that. But it should help anyway.
Thats not too bad, the only time you really need to worry about changing them is if the fins are paper thin or if they look like and old battery terminal, curroded as hell.
i wish i still had the pics of the one i pulled off my Jimmy when i first bought it, mine was missing 3 fin's and the others were paper thin and ready to burn off and the damn thing still ran.
GMC's are awesome trucks lol
My apoligies to the OP i dont mean to hijack your thread (but it beats starting another),, but all the tire talk got me wondering. Like some of the posts here my door says 225 as the tire size, when i bought the truck it had 245's on it (even the spare). i put 265's on it. I've read on here about tire size and gearing,,,,, 265's arnt to big are they? i have nothing major in my axel except anti-slip.... so no "sup'ed" up gearing. Like the OP, my milage sucks and after reading this thread I realize i "must" be getting a little bit better milage than the "9" the overhead console is telling me based on my speed no being right (BTW what's it run moola wise to get that adjusted),, but would i be in that situation where, with the bigger tires my gearing isnt right????
thanks (and again, sorry for the hijack)
Your truck is a heavier extended cab powered by the smaller 5.2, it will get a lesser miles per gallon. Do you carry a heavy sound system or a bunch of tools? That may factor in the mph along with the mentioned HUGE tires. I had my converter hollowed out on my 5.9 2wd and it runs much better with more throttle response and better mpg. It is a little louder but it sounds good with the stock muffler, good rumble and not too loud. I bought this truck new Aug '96, 172,xxx mi, and it runs better than ever other than the chattering valves when I hammer on it.
Over the past couple of days I have borrowed a GPS from a friend to find out exactly how far and fast I am going. If I use the numbers from the GPS with the 305-70/16 size tires on my extended cab 2wd 5.9L truck I am averaging 12.47 MPG. This over 5 tanks of fuel. When I get to work which is almost exactly 40 miles from home there is almost a 5 mile difference in reading from the odometer and the GPS.
2000 ram 1500 4x4 reg cab short box. 285/75/16. 12.5 mpg, pod lift, superchips, i run it hard, babying it will just cause more problems in the long run. i only use stock parts in tune ups. if you use after market cap rotor and bosh/autolite anything other than stock it will not perform as it should. that engine is designed around champion. when the truck had 60k miles, it started getin gutless, kinda took a little while to start in the am. replaced the fuel pump and what a difference! these trucks are like women, so freakin high maint!
Your truck got gutless because the lower intake gasket is blown!
