Failing U-joints/goin out?
Old Feb 15, 2010 | 02:03 AM
Bubba39047's Avatar
Bubba39047
Default Failing U-joints/goin out?
Could someone tell me the signs of ujoints goin out? i think mine are startin to go out..
Old Feb 15, 2010 | 02:32 AM
yakkier's Avatar
yakkier
Ticking, shaking while going straight in 4x4. worn or crusted yokes
Old Feb 15, 2010 | 09:17 AM
95RAM360's Avatar
95RAM360
you'll notice clunking, and possibly a sway,
have you checked them visully by grabbing each cap and trying to move it
Old Feb 15, 2010 | 10:01 AM
Sheriff420's Avatar
Sheriff420
Clunking when you first hit the gas or let off it, drive line vibration while accelerating/cruising and squeaking at low speeds are a good indicator. You're talking about the drive shaft on the 2wd right?
The quick test (if it is bad enough) would be to grab the drive shaft and try to spin it while watching for moement the u joints.
The best way would be to drop the drive shaft and hold it in one hand and the yoke in the other and move them around, you should know for sure if one of them is bad by doing that.
Old Feb 15, 2010 | 01:27 PM
Bubba39047's Avatar
Bubba39047
It is sort of sweaking when i am in reverse. I will check it today, physically. Its been so wet i couldnt have if i wanted to.
Old Feb 15, 2010 | 07:37 PM
Sheriff420's Avatar
Sheriff420
Blown wheel cylinders can squeak from the rear at low speeds also.
Old Feb 16, 2010 | 10:36 PM
Bubba39047's Avatar
Bubba39047
well i mean it drives fine. Just kinda makin noise sometimes. and it may be nothin, i may just be paranoid.
Old Feb 17, 2010 | 02:01 AM
Sheriff420's Avatar
Sheriff420
Mine had a slight squeak at low speeds that progressed into a pretty loud squeak before i changed the u joints out. You need to go ahead and check them, you don't want the drive shaft to fall off because a cracked u joint cap fell out.
Old Feb 18, 2010 | 07:35 PM
Bubba39047's Avatar
Bubba39047
well no i dont. Gosh need u-joints and shocks, and new tires in like 10k miles..
Old Feb 18, 2010 | 08:29 PM
iwhitne's Avatar
iwhitne
join the club
