Small rim...?
Old Feb 15, 2010 | 12:08 PM
Kingsnap's Avatar
Kingsnap
550 for four tires that is a great price! I will be doing some shopping i guess!!
Old Feb 15, 2010 | 01:49 PM
wermbang's Avatar
wermbang
Cheapest I found online was $154 each plus shipping. You may be able to go to goodyear dealership and check on the sale prices or specials.
http://www.tireteam.com/tiresearch?&...&prange=&promo=
Old Feb 15, 2010 | 06:24 PM
Kingsnap's Avatar
Kingsnap
Very nice!!
Old Feb 15, 2010 | 08:40 PM
wermbang's Avatar
wermbang
Thanks.
Old Feb 15, 2010 | 08:57 PM
dhvaughan's Avatar
dhvaughan
transmission service at a shop will run anywhere from $100-200.
you should do it yourself. its not hard, just a little messy. if you take the opportunity to put in a drain plug, it'll make it easier and neater next time. cost of fluid and filter is about $50.
and this is important.. if your truck has not had regular transmission service, then you'll notice a heavy coat of gray sludge inside the pan, and all over the bottom of the valve body. you can clean the pan, but understand that the entire transmission is coated in that same sludge. your new transmission fluid is loaded with detergents which will break loose that sludge and put in back in suspension, where it will pretty soon clog up your new filter, which will pretty soon ruin your transmission. also know that draining the fluid only actually drains about half of the old fluid. so - there is a huge benefit to changing the fluid a couple of times, about 2 or 3 or 4 weeks apart.
don't use any other fluid than ATF+4.
http://www.pavementsucks.com/tech-article-39.html
