Engine runs rough, dealer has no idea why
Old Feb 20, 2010 | 02:46 PM
  #41
babyhuey6810's Avatar
babyhuey6810
You really need to check for a vac leak.Spray a can of brake clean around the intake and throttle body.Sometimes the throttle body base gaskets dry out and cause air leaks.Used to be pretty common on old TBI injected GM cars and trucks.
Old Feb 21, 2010 | 12:09 AM
  #42
Hammer Down's Avatar
Hammer Down
Replace the gasket regardless. It takes $2 and 10 minutes.
Old Feb 22, 2010 | 12:52 PM
  #43
Sitnback13's Avatar
Sitnback13
Which gaskets do I need to replace> There is one on top of the Throttle Body which attaches to the Air Filter. Otherwise Im lost here
Old Feb 22, 2010 | 01:33 PM
  #44
Hammer Down
I mean the gasket in between the throttle body and intake manifold. The one between the air cleaner and throttle body is important, but not quite as essential. It should be replaced too if its in poor condition.
Old May 3, 2010 | 08:50 PM
  #45
Hjhf1500's Avatar
Hjhf1500
It could be your vacuum booster or the check valve on the vacumm booster,try to have it checked,a vacuum leak can also make the oxygen sensors read lean or rich.
