long tubes scavenge the exhaust gases better along with a better power band, also the long tubes are better if any sort of boost is in your future or higher rpm driving. Shorties to create a few more hp over long tubes but later fall flat in the power band. Read all this in a mopar magazine
Read that too, but the LT create more than the shorties. On a dyno test shorties created +7 HP over the stock manifold, while the LT made +13.
i wanna see how that y pipe will fit with the transfer case.... been thinking on longtubes also but not to sure about that... long tubes into a x pipe in to exiting at the corners would be cool.. bet it would sound killer too.
Did you get them put on yet? I'm really interested in how they sound/fit/feel. I want to get the exact same setup but with ceramic coating. My only problem is that my truck is a 2500, and according to summit racing these parts are not compatible with a 2500. I don't understand...are they really that different between the 1500 and 2500?
