Load Range
Old Feb 21, 2010 | 05:48 PM
notanexit7's Avatar
notanexit7
Default Load Range
Uh...this might be a stupid question but I'm gonna ask anyway. The tires I'm buying next week only have load range e in 265 75 16's. Is there any negative effects going from a c to an e?
Old Feb 21, 2010 | 06:00 PM
dhvaughan's Avatar
dhvaughan
actually E is a much heavier capacity tire than C or D. No negative effects.
Let me look for a chart.
http://www.tirerack.com/tires/tirete....jsp?techid=55
Load Range Ply Rating Load Pressure (psi)
B 4 35
C 6 50
D 8 65
E 10 80
F 12 95
weight capacity wise, when properly inflated, load per tire is something like this. (more or less).
the difference is the # of plies rating, and sidewall strength.
C - 1700 @50
D - 1900 @65
E - 2200 @80
Old Feb 21, 2010 | 06:50 PM
bardram's Avatar
bardram
I would say yes there is a negative effect, the ride quality will be a bit different, but nothing severe.
Old Feb 21, 2010 | 07:18 PM
notanexit7's Avatar
notanexit7
Thanks dhvaughan. I don't think I'll be too concerned with ride quality. It already rides like a tank anyway and I can't see it getting much worse haha. To bad they only make these tires in the E range.
Old Feb 21, 2010 | 07:27 PM
chromed95's Avatar
chromed95
what kind of tires are you getting?
Old Feb 21, 2010 | 07:38 PM
dhvaughan's Avatar
dhvaughan
set your air pressure to a reasonable level. if your just driving around on the street, 35-40 is fine. if you're hauling heavy loads, you can air up to 50-60-70. but BEWARE, the front end gets very skatey at high pressures and unloaded condition.
Old Feb 21, 2010 | 07:49 PM
VEETEN's Avatar
VEETEN
The only Real negative effect I've had with 10 ply is the price....
I'm stepping down with the next set cause I don't do much hauling anymore..
What kind are you getting?
Old Feb 21, 2010 | 10:40 PM
notanexit7's Avatar
notanexit7
I was gonna get the general grabber at's but I might reconsider. I do not need 10 ply tires, I just don't haul that much anymore. The grabbers were $140ish. I didn't think that was too bad an asking price so I think I'm gonna do a little more shopping around for tires in that price range.
Old Feb 21, 2010 | 11:17 PM
iwhitne's Avatar
iwhitne
you should check out the treadwright thread they're running between $75-$104 each and i think they have a tread pattern like the grabbers
www.treadwright.com
Old Feb 22, 2010 | 07:53 AM
notanexit7's Avatar
notanexit7
i've put my .02 cents in that thread before. idk i'm a little skeptical of the treadwrights
