5.9L crank into 5.2L block???
Old Feb 21, 2010 | 08:06 PM
wpayne7's Avatar
wpayne7
Exclamation 5.9L crank into 5.2L block???
Hey guys,
I'm wondering if anyone knows if a 5.9L crank would fit into a 5.2L block. I currently have a 1995 Dodge Ram, 4WD, with a 5.2L/318 cubic in. and I'm looking to rebuild the motor. My intent is to increase the horsepower of the motor. Thanks in advance!
Old Feb 23, 2010 | 08:15 AM
dmor360's Avatar
dmor360
yes sir. same thing with cam and heads i believe.
Old Feb 23, 2010 | 09:34 AM
Hammer Down's Avatar
Hammer Down
I don't think so. The two engines are very different intternally. the 5.9 crank is externally balanced and the 5.2 is internally balanced.
Old Feb 23, 2010 | 01:18 PM
zman17's Avatar
zman17
Retired Moderator - RIP
+1...... It is not that simple!
Old Feb 23, 2010 | 01:55 PM
quackaddict's Avatar
quackaddict
yeah but that balancing effects the crank which he is replacing. If I am not mistaken and I probably am it is the same block just bigger cylinders right? That is why when I bought my crate 360 long block I pulled everything off my 5.2 and it bolted right up. probably wrong you would have to have the cylinders bored out but I think it would fit.
Flywheel, flexplate and harmonic balancer are different but that is all outside the block.
Good question though.
Old Feb 23, 2010 | 02:03 PM
Gerehead8's Avatar
Gerehead8
I will look in my service manual to see if the journals are the same size. I will post later today.
