Anybody ever taken ABS out of their truck?
I have a 1998 2500 extended cab 4x4 5.9 With a 5 speed. I had to replace the front wheel hubs. I opted for the ones with out the ABS sensors. It came equiped with 4 wheel ABS. I would at the very least just like to get the light on the dash off. I tried pulling fuses, disconnecting the wiring harness. Nothing. Any suggestions?
PO pulled all the wires underneath the truck for ABS..also pulled the clips in the relay box,and left the sensors...all i had to do was pull the bulb, it took about 6-8 minutes to do that...
been running without ABS for at least the last 10K miles to my knowlege i like it better without ABS..cause im in more control..i know safety wise it is better to have it..but eff that noise...none of our vehicles have ABS
although i think if your state/county requires emissions and ****..wouldnt not having functioning ABS cause you to fail your test?
