Rear-End Rebuild, Hows My Contact Pattern Look?
Old Feb 22, 2010 | 10:02 PM
Dizzydan02's Avatar
Dizzydan02
Default Rear-End Rebuild, Hows My Contact Pattern Look?
Im rebuilding the rear-end in my '99 Dodge 4x4. Its a 9.25 trac-lok. Gears, bearings, and races are brand new.
I think I set-up the backlash and carrier bearing pre-load correctly I would just like a second opinion.
Here are a couple pictures of the contact pattern. Hopefully you guys can see it fine, I didnt use a whole lot of gear marking compound.
The last thing I want to do is take the pinion back out, I dont have any way to pull the pinion bearing back off if I need to install or remove a shim. So hopefully this is good enough.
Old Feb 22, 2010 | 10:06 PM
master tech's Avatar
master tech
Site Moderator & Tech
Could add a .010 shim to bring the pinion back, just a bit.
Old Feb 22, 2010 | 10:09 PM
babyhuey6810's Avatar
babyhuey6810
+1 to the mod,kinda deep too.
Old Feb 23, 2010 | 12:03 AM
Dizzydan02's Avatar
Dizzydan02
Is it bad enough that you guys would tear it all back apart? If I have to take it all back apart I will have to spend the money on a pinion bearing puller...which isnt cheap.
Old Feb 23, 2010 | 12:06 AM
master tech
It could start howling. How much backlash do you have?
Old Feb 23, 2010 | 12:18 AM
Dizzydan02's Avatar
Dizzydan02
Backlash is set at .007
