PLenum gasket
Old Feb 24, 2010 | 06:07 PM
PurplDodge's Avatar
PurplDodge
.....Or cut your own plate out. Just throwing that out there!
Old Feb 25, 2010 | 11:52 PM
Cheek-oh!'s Avatar
Cheek-oh!
im doing the plenum plate but got stuck at the part where you have to take off the lines... tore down the whole front end and im stuck.....
Old Feb 25, 2010 | 11:56 PM
PurplDodge's Avatar
PurplDodge
The fuel line? You need a fuel line quick disconnect fitting tool.
Old Feb 26, 2010 | 12:00 AM
dodgeram07's Avatar
dodgeram07
or just unbolt the fuel rail form the intake man and pull the fuel rail with the intjector off the intake man
and sum time you can use two small srew drivers also
good luck
Old Feb 26, 2010 | 12:07 AM
Cheek-oh!'s Avatar
Cheek-oh!
woot woot! im gonna do that tomorrow.... hopefully i'll be able to do it.... i mean.... i'm halfway there anyway.....
Old Feb 26, 2010 | 01:56 PM
Sheriff420's Avatar
Sheriff420
The fuel line disconnect tool is only a few dollars. If you do pull the fuel rail off then don't forget that you will need new o-rings and you will need to lubricate each o-ring with some clean motor oil before installing the injectors.
