crank position sensor
Old Feb 23, 2010 | 02:30 PM
1fast2liter's Avatar
1fast2liter
Default crank position sensor
ok i cant seem to get to the crank position sensor or even see it... so how is it changed and whats the location exactly so i know and whats the size of the bolts that hold it in? diagrams would be helpfull.
Old Feb 23, 2010 | 03:08 PM
Gerehead8's Avatar
Gerehead8
It is right behind the passenger side head. It uses cap screws to hold it in. I think a 1/4" allen wrench works to get the bolts out. You may be able to back them out from the engine compartment rather than from underneath the truck. It is a PITA but doable.
Old Feb 23, 2010 | 04:58 PM
quackaddict's Avatar
quackaddict
I hear all these stories about what a PITA this is but mine was real simple. I just laid under the truck it is behind the passenger side head sandwiched between the tranny and engine. Mine has 2 1/2 bolts holding it in.
Old Feb 23, 2010 | 05:26 PM
xxxcowxboyxxx's Avatar
xxxcowxboyxxx
+1 on it not being very difficult to change. im a smaller guy so reaching up there was cake work
Old Feb 23, 2010 | 06:23 PM
blong4life's Avatar
blong4life
Just replaced mine, tape a 1/4 allen biut into a socket that will fit (1/4" drive), and put some extentions on it. Bolts were easy to get out this method, hands too big to reach in there and you can tap the long apaeratis on with a hammer needbe to get rust, etc out. OEM sensor works best for this, I got a BWD from advanced and it got taken out by the flywheel on the first crank, beware.
Old Feb 23, 2010 | 08:05 PM
1fast2liter
well after talking to a tech for a bit i went and had the codes read.. cylinder 5 missfire wich i figured then i got 2 o2 codes right away before the missfire.. so i went to get another one to put in but its frozen in their by rust a crap so now i got to figure out how to get it out. worst of all the top portion twisted right out and took the wires with it... so now i need to figure a sure way to get it out.
