That sounds about right. I have the 3.92 gears and drive 40 miles each day to work and back. I roughly get 260 to 280 a tank if I let it go past half. Usually I fill up at half a tank just cause its a little easier on the wallet each time. But when I do fill it up at the light I put about 23 gal in it. If I do it on the line just before E I put about 20gal in it. So when I calculate my mpg its around 12 usually. But I didn't buy her for the gas mileage. I have a mustang for that. I bought her for her sheer beauty and power.
After I replaced all my spark plugs and crap I got 16 mpg but after I got exhaust it went back down to around 13 or 14 mpg bc I get on it too much now.
I didn't run it until light came on the first time which was the 264. I think if I had of, I might have gotten near 300, I have a gutted cat and a flowmaster with turndowns and crappy tires and a misfire on cyl. 8. So i guess i shouldn't complain! :-)
this is the dumbest thread on here!.. what are you trying to say?
You said you got 264 on a full tank but the light never came on? There should be a law against posting anymore MPG threads!
Don't get your panties in a wad! I was just curious as to if this was normal. I didn't buy it for the mileage either, i just drive back and forth to work 10 miles a day. I just happened to make a trip to st.louis in it to give it a good run and see what all it would need and not need.
thats about normal. my rpms are a bit lower at 70, mine are at about 1500. im on 35's with 3.55's, my digital gas thing stays consistant between 15-16 on all highway and 11-12 around town, and i reset it on fill ups so i know its accurate
