Can I unhook the lockouts on my 98 Ram?
Old Feb 24, 2010 | 09:20 AM
blbikerood's Avatar
blbikerood
Default Can I unhook the lockouts on my 98 Ram?
Is that possible?
Old Feb 24, 2010 | 11:09 AM
Sheriff420's Avatar
Sheriff420
What is a lockout?
Old Feb 24, 2010 | 11:16 AM
Maxx_Magnum's Avatar
Maxx_Magnum
I think he's talking about the lock up clutch in his tranny.... I saw something mentioned in another thread...
I have no idea if it can be disabled or not
Old Feb 24, 2010 | 11:58 AM
olyelr's Avatar
olyelr
Um, if you are talking about the hubs, then no. They are full time... the shafts are connected to the hub with splines.
Old Feb 24, 2010 | 12:02 PM
blbikerood's Avatar
blbikerood
Default no the torque converter
is making the truck shake cuz it isn't going back in when it locks out.
Old Feb 24, 2010 | 12:10 PM
Sheriff420's Avatar
Sheriff420
Have you changed your transmission fluid/filter lately? If so then what kind of fluid did you use?
Old Feb 24, 2010 | 12:15 PM
blbikerood's Avatar
blbikerood
Smile that will be this weekend
I've only had it since last thursday night, I haven't changed anything in it other than the oil and the plugs. Going to change the fan clutch tonight and hopefully the door hinge pins.
Old Feb 24, 2010 | 12:25 PM
Sheriff420's Avatar
Sheriff420
Find out if the previous owner put dexron fluid in the transmission (if you can). ATF 4 is what needs to be in the transmission and if you use dexron instead, you can experience "torque converter shudder".
Old Feb 24, 2010 | 12:37 PM
blbikerood's Avatar
blbikerood
Default cool
will do. Thanks!
Old Feb 24, 2010 | 02:23 PM
Gerehead8's Avatar
Gerehead8
By the way a Torque Converter does not have "lockouts". They have a lock up clutch that presses agiants the face of the torque converter to "lock up" the converter. This is not the same as stall, just so you know.
