Psi?
Old Feb 24, 2010 | 06:58 PM
Eddielx's Avatar
Eddielx
I think my truck calls for 65 front and 80 rear. That sounds kind of high.But that is with 245 tires I have 265.
Old Feb 24, 2010 | 07:14 PM
jasonw's Avatar
jasonw
Site Moderator
Originally Posted by DukesOfHazzard
I run whatever the sidewall says to, usually 50 psi also, keep up on air pressure ,alignments and maitenace and the tires should last a long time.
Usually that number is the MAX pressure, not the recommended amount.
For my 265s, rated at 45 PSI max IIRC, I run usually around 36 PSI. Any more or less, the tires start to wear strangely.
Old Feb 24, 2010 | 07:31 PM
redheadhunter21's Avatar
redheadhunter21
Dont worry about helping the OP I think he is having a vacation from the forum, he decided to be big and bold to the wrong person
Old Feb 24, 2010 | 07:34 PM
Eddielx's Avatar
Eddielx
Is anyone else running the 65 front 80 rear or am I reading the door tag wrong?
Old Feb 24, 2010 | 07:40 PM
redheadhunter21
Do you tow on a regular basis, if not I would lower the psi down some will help smooth the ride a little a downside though it might lower mpg. Do you have E load range tires, because thats past the max of most tires
Old Feb 24, 2010 | 07:55 PM
jasonw's Avatar
jasonw
Site Moderator
I can see that, I was just posting for everyone else's benefit.
Old Feb 24, 2010 | 08:00 PM
iwhitne's Avatar
iwhitne
I'm running 36.83627283 psi in the front and 36.83627284 in the rear..
come on people... if you don't know what psi to run then you shouldn't be driving ANY vehicle!
Old Feb 24, 2010 | 08:21 PM
redheadhunter21
Really is that the best tire psi to use
And I want to know were to buy that tire pressure guage
But seriously I have my fronts a 42 and the back at 45
Old Feb 24, 2010 | 10:17 PM
iwhitne's Avatar
iwhitne
40 in summer... 34 winter
Old Feb 24, 2010 | 10:58 PM
dhvaughan's Avatar
dhvaughan
why is OP on vacation ?
other than starting about 99 different threads on this same subject...
