Psi?
Old Feb 25, 2010 | 12:41 AM
  #21
redheadhunter21's Avatar
redheadhunter21
There is a locked thread about steering that he just started blasting anyone who tried to help
https://dodgeforum.com/forum/2nd-gen...l-opinion.html
Have a look at the ones he was disrespecting and their titles
Old Feb 25, 2010 | 04:39 AM
  #22
Sheriff420's Avatar
Sheriff420
I run 52 in the front and 48 in the rear (tires rated for 65), that makes the tread contact the ground evenly all the way across.
Old Feb 25, 2010 | 10:20 AM
  #23
Eddielx's Avatar
Eddielx
My tires are rated to 80psi.I think they are 10ply tires.I just had a plug put in my tire at a tire shop and when I ask how much for new tires I was told my truck needs 10ply because its a hd truck.
Old Feb 25, 2010 | 10:26 AM
  #24
Aubrey's Avatar
Aubrey
Eddie - find a new tire shop
Old Feb 25, 2010 | 10:57 AM
  #25
DODGEPWR's Avatar
DODGEPWR
I run around 36 in front and 35 in rear... My tires are 80 psi max. I wonder if i should up my PSI? It rides great, i live on a really bad road that has craters and washout spots in all in it. It also gets really muddy when it rains. I have never got stuck. I wonder if it would ride too rough or loose traction if i uped the PSI alittle. I guess it wouldnt hurt to try while my road is not muddy.
Old Feb 25, 2010 | 01:24 PM
  #26
Eddielx's Avatar
Eddielx
Any reason for that?Or are you just trying to get your post count up?
http://www.tirerack.com/tires/tirete....jsp?techid=55
Old Feb 25, 2010 | 02:00 PM
  #27
Sheriff420's Avatar
Sheriff420
The guy said that you need a 10 ply because your truck is capable of exceeding the maximum weight capacity of a load range d-8 ply tire. If you don't overload the tires then you can put an 8 ply tire on there and be fine.
Old Feb 25, 2010 | 02:36 PM
  #28
dodge15004x45.9's Avatar
dodge15004x45.9
You don't need 10 ply tires. I have E's on my 1500 and I don't need them.
Old Feb 25, 2010 | 08:04 PM
  #29
redheadhunter21
Do you tow close to the max for your truck, if you told your tire guy that I could understand him saying that, but if not then he just wanted your money.
If you use your truck to tow a small trailer around then you will have no problem with a lower range tire, I have E load range tires on my truck because when my dad drove it he towed a boat and needed the extra weight capacity. But my next tires will be D load range because the biggest thing I tow is a 16 foot trailer full of atv/atc's.
And I'm surprized that the inside of your tires are not wearing crazy fast compared to the outside
