alternator
Old Feb 26, 2010 | 04:27 PM
bangedupbutbangin's Avatar
bangedupbutbangin
Default alternator
i have to loosen the tension pulley on the belt to remove the alternator right???
dont i just back off the screw in the center of the tension pully?
Old Feb 26, 2010 | 04:32 PM
95RAM360's Avatar
95RAM360
no you dont, the alternator takes like 15 minutes to take out....take off belt by pulling forward on the tensioner (towards drivers side), electrical connectors, the 4 small nuts on the back holding the connector, and the 2 bolts that hold the alternator on.....Do you hve a haynes or Chilton repair manual? if not id recommend getting one........Alternator is a very straight forward job, and doesnt require taking off other items....except maybe a bracket, but i cant remember right now...
Old Feb 26, 2010 | 04:33 PM
Sheriff420's Avatar
Sheriff420
tighten the 15mm bolt in the center of the tensioners pulley and the tensioner will move enough to slip the belt off the alternator pulley.
Old Feb 26, 2010 | 04:36 PM
bangedupbutbangin
Thanks sheriff420!!! Thats what i thought that would make it do right...
Old Feb 26, 2010 | 04:44 PM
Sheriff420's Avatar
Sheriff420
Yep. I just popped mine off yesterday to listen to all of the pulleys with the stethoscope, it was so cold that the belt kept its shape after I took it off.
95RAM360's Avatar
95RAM360
did your alternator have a loud whine? mine des and im not sure if i should get ready to replace it.
Old Feb 26, 2010 | 04:45 PM
notanexit7's Avatar
notanexit7
If your replacing the alternator make sure you get the right one. I got a new one and it didn't have a plug in the back like my old one had and I had to send it back. Also make sure it's got the same amps as your old one.
Old Feb 26, 2010 | 05:42 PM
Cheek-oh!'s Avatar
Cheek-oh!
took mine off real quick and i got a 130 for my stereo set-up
Old Feb 27, 2010 | 08:15 PM
pavement_hater's Avatar
pavement_hater
I upgraded from the 117 amp to the 136 amp and only had to change the end on the wire running to the power dist. box. The post is larger on the 136 amp.
Old Feb 28, 2010 | 02:45 PM
dhvaughan's Avatar
dhvaughan
STEP 1 of anything electrical - disconnect negative battery cable, or you run the risk of pcm damage. its not worth the risk.
