headlight switch/fog lights
Old Feb 26, 2010 | 06:52 PM
eldrm's Avatar
eldrm
Default headlight switch/fog lights
My fog lights have stopped working, checked fuses, although none were specifically for foglights, they all looked good. Could the "pull out for foglights" headlight switch be the culprit? the wiring all looks fine also, thanks for any ideas on this!
Old Feb 26, 2010 | 07:37 PM
jasonw's Avatar
jasonw
Site Moderator
Welcome to DF!
If you have factory fog lights, there is a single fuse for them in the PDC under the hood that you should check.
If that tests good, or you have aftermarkets spliced into the headlight switch, the switch may very well have failed. The factory switches are known to be weak.
I'd check that fuse first though.
Old Feb 26, 2010 | 08:11 PM
codyselcamino's Avatar
codyselcamino
your relay could be bad too, its under the hood too
Old Feb 27, 2010 | 08:17 AM
eldrm's Avatar
eldrm
thanks for the info! I'll clear last nights snow off and check it out-Ed
Old Feb 27, 2010 | 08:39 AM
CSXfan's Avatar
CSXfan
Get a voltmeter and start checking things. Don't go out and buy a new switch unless you know for sure it's bad (I made this mistake and it cost me $60 when I could have fixed it for nothing). My fog lights quit working because of a splice that corroded and fell apart. Just check for voltage starting at the light and work your way back toward the switch.
Old Feb 28, 2010 | 10:11 AM
eldrm's Avatar
eldrm
Thanks, I'll check that before spending. have it down to the switch, or possible bad wiring, fuses and relay checked out ok
Old May 14, 2010 | 10:50 AM
SunhawkRam's Avatar
SunhawkRam
i know that this is an old thread...recently my fogs quit working...I press the button, it lights up, when I release it, it quits. My fogs don't turn on at all when I do this either
Old May 14, 2010 | 11:16 AM
Have a look thru this thread.
