Sawzall or Cutting wheel?
Old Feb 27, 2010 | 06:35 PM
Mudshack's Avatar
Mudshack
Default Sawzall or Cutting wheel?
I am planning on putting a dual exhaust on my stock 5.9L. Do you guys suggest getting a sawzall to cut the pipe or a cutting wheel? (I will also be replacing a bent tip on my wife's Jeep, so this will get multiple uses.)
Old Feb 27, 2010 | 06:40 PM
DukesOfHazzard's Avatar
DukesOfHazzard
sawzall can get creative with one..thats what i used to hack my exhaust off in a few seconds.
Old Feb 27, 2010 | 09:33 PM
yakkier's Avatar
yakkier
Sawzaw with a short blade, grinders are great for cutting in open area's but trust me you dont want to run a chance of dropping it while your under there. Iv got a scar across my shoulder where i lost my grip and droped it while it was on.. and yea...
Old Feb 27, 2010 | 09:37 PM
Gerehead8's Avatar
Gerehead8
A sawzall will make much straighter cuts also.
Old Feb 27, 2010 | 09:57 PM
95ram5.9's Avatar
95ram5.9
Another vote on the Sawzall. I used a grinder and it melted through the exhaust rather than actually making a clean cut.
Old Feb 28, 2010 | 11:45 AM
Sheriff420's Avatar
Sheriff420
I just used my sawzall a couple weeks ago to hack up mine. It takes 5-10 seconds to chop a 2.5" exhaust pipe off.
Old Feb 28, 2010 | 12:01 PM
dodgeram07's Avatar
dodgeram07
[QUOTE=yakkier;2023142]Sawzaw with a short blade, QUOTE]
mmmm i go for sawzall with a longer blade(for cutting metal) lager than the size of the pipe so it doesn't buck on you when cuttting
Old Feb 28, 2010 | 12:12 PM
Sheriff420's Avatar
Sheriff420
6" blade works. If the blade is too long then you might punch the bottom of the body.
Old Feb 28, 2010 | 01:41 PM
wjxavier's Avatar
wjxavier
not to be off topic, but sheriff i cant stop staring at your avatar...lol
oh...sawzalll FTW.
Old Feb 28, 2010 | 01:43 PM
CPTAFW163's Avatar
CPTAFW163
SAWZALL:
The reason i don't have my sidepipe exhaust from the truck in my sig is because I cheapied out and bought a cutting wheel the day before I moved. It could not budger through a heavy duty aftermarket exhaust.
Get a sawzall. It is necessary. unless you know someone who is an electrician, blumber, carpenter or in the contracting business.
I used my cousin's sawzall to cut my exhaust system and it worked like a charm. Cutting wheel might fall out of your hands.
