RAM 1500: 2" lift with longer shocks
Old Feb 28, 2010 | 01:25 PM
CruiserY2K's Avatar
CruiserY2K
Default RAM 1500: 2" lift with longer shocks
Hi guys,
I am ready to mount 2" spacers at the front and 2,5" add-a-leafs at the rear.
Now i have read, that it is recommended to add some longer shocks, too.
By the way: a have already mount a skyjacker 3" Bodyliftkit on my RAM 1500.
Which shock types do you prefer ?
I want to mount nitro shocks, and i do no offroading with my truck.
What do you think about the skyjacker nitro shocks type N8017 ( rear ) and N8092 ( front ) ?
At summit racing i have also found these shocks:
Rancho RS5221.............( 0-3" )..eyelet/stud, twintube - front only
Trailmaster 72670..........( 2" ).....eyelet/stud, twintube - front
Trailmaster 72680..........( 2" ).....eyelet/eyelet, twintube - rear
Bilstein F4-BE5-6681-H6..( 3" )......? / ? monotube - front
Bilstein F4-BE5-6682-H5..( 0-1" )...? / ? monotube -rear
Bilstein F4-BE5-6647-H1..( 4" )......? / ? monotube - rear
ProComp Mx 6146...........( 3" ).....eyelet/stud, monotube - front only
What do you use ?
Old Feb 28, 2010 | 01:33 PM
halfamil's Avatar
halfamil
I couldn't tell the difference in the stock shocks, Gabriel HD's, or the Bilstein's. I've had all three on it. They are all stock lenth though.
Old Feb 28, 2010 | 01:39 PM
Sheriff420's Avatar
Sheriff420
With 5" total lift then you will want shocks designed for a 5" lift.
Old Feb 28, 2010 | 02:17 PM
zje400ex's Avatar
zje400ex
He said he has a body lift. You do NOT need longer shocks when using a body lift. Only suspension.
You should buy shocks for a 2-3 lift. Rough country's will be just fine. They cost me $120 for all four and black shock boots.
Old Feb 28, 2010 | 02:19 PM
Gerehead8's Avatar
Gerehead8
You beat me to it.
He has a 2" lift. The rest is body lift which has no effect on the suspension. Get shocks designed for a 2 in lift.
Old Feb 28, 2010 | 02:30 PM
DukesOfHazzard's Avatar
DukesOfHazzard
I have those Trailmaster SS right now same #'s to boot and they worked out good, but there due for replacement, gonna get Bilstiens 5100's or KYB monomax if i can find them.Looking for a monotube shock is a better deal.
Old Feb 28, 2010 | 04:14 PM
CruiserY2K's Avatar
CruiserY2K
thank you guys,
and yes i need only shocks for a 2" lift - that´s right.
Ok, i try to find out some technical details about the rough country´s, Bilstein 5100´s and the KYB monomax shocks.
Can you name some us part dealer to me ?
( ... especially which do overseas shipping )
Old Mar 1, 2010 | 05:52 AM
CruiserY2K's Avatar
CruiserY2K
Hi guys,
i have changed my mind and want to buy Bilstein 5100 shocks now.
These items are high quality shock absorbers - exactly what i want.
I took a look at the Bilstein Catalog and found these part numbers:
RAM 1500 4WD 94-01:
front 3"......BE5-6681-H6
front 5-6"...BE5-6646-H6
rear 0-1"....BE5-6682-H5
rear 4".......BE5-6647-H1
At shockwarehouse.com i found these different numbers:
( .... but why ?? )
front 3".....BE5-6681-H8
rear 0-1"...BE5-6682-H8
Note:
Compression bump stop on chassis may need to be modified to prevent damage to the shock absorber.
There are no other shocks for a lifted RAM 1500 available.
No shocks for exactly 2" front and 2" rear.
What can i do ? Would you buy "the 3" front and 0-1" rear choice" ?
... and what about the note to the compression bump stop ??
Do i need longer bump stops now ? ( where to buy ? )
I am a little bit confused now.
Old Mar 1, 2010 | 07:09 AM
jasonball's Avatar
jasonball
when doing the body lift don't you have to worry about the steering. and it not reaching.
Old Mar 1, 2010 | 08:30 AM
95RAM360's Avatar
95RAM360
yes, as well as extend brake lines, any wiring etc.
