transmission issues
Old Feb 28, 2010 | 10:20 PM
Kody's Avatar
Kody
Hi,
thank you for the help,
I will pull the pan off and drop the tranny. Is there a way to tell if the TC is shot once i get it out?
Thanks again,
Kody
Old Feb 28, 2010 | 11:17 PM
halfamil's Avatar
halfamil
Originally Posted by CPTAFW163
I don't know of anyone that owns one of these dodges that doesn't have some type of tranny "issue" when it is over 70K.
The other makes, are the same way. Mine failed at 368k. Never an issue, it just stopped one morning.
Old Mar 1, 2010 | 01:05 AM
cwdxd4's Avatar
cwdxd4
Mine did the exact same thing when I bought it. The guy thought the transmission was blown and it wouldn't do anything except for a whine similar to a p/s whine. When I dropped the pan the fluid was just a goey gel. But, I changed the fluid it's still running 1 1/2 years later!
Old Mar 1, 2010 | 07:28 AM
Kody's Avatar
Kody
that is interesting, I will pull the pan and check it out. I don't know if the fluid has been changed or not but if it is all goey like you say i will change it and see what happens.
Thanks,
Kody
Old Mar 1, 2010 | 09:01 AM
gnome's Avatar
gnome
I just went through this last weekend. I didn't know anything about the sensors until finally my check engine light came on....not sure why my tranny acted up for so long without a trouble code coming up. For me, I got two codes...output speed sensor and governor pressure switch. At first I just did the output speed sensor...got overdrive back, but then had problems with 2nd and 3rd. Saturday I dropped the pan and replaced the governor sensor and solenoid....My tranny is back to tip top shape. Thank God it wasn't anything more than that!!!!
Old Mar 1, 2010 | 09:56 AM
95RAM360's Avatar
95RAM360
everyone will have tranny problems unfortunatly.......but the rh's are more durable than the re's....
