How to get the o2 sensor out?
Old Mar 3, 2010 | 03:23 PM
  #21
Gary-L's Avatar
Gary-L
Veteran: Navy
Originally Posted by Sheriff420
I was reading a thread on an antique tractor restoration forum and they tested a few different penetrating fluids by scientifically rusting a number of bolts and testing the torque needed to remove each one. wd took the most torque, then pb blaster, then liquid wrench took half as much as pb, then aerokroil took a few pounds less than liquid wrench and the atf/acetone mix took half as much as the aerokroil.
Thanks for the info. When I'm dismantling the old VWs, I use PBlaster and heat. I've heard very good stuff about Kroil's abilities.
Old Mar 3, 2010 | 10:26 PM
  #22
jamesnb's Avatar
jamesnb
PB Blaster does make some lubricants but I'm pretty sure the stuff I use is for busting loose nuts and bolts. I've had pretty good luck with it even on my 23 year old in-board boat and 30 year old Mercedes. Once in a while I do twist off a bolt head but it works much better than WD-40.
I havn't tried Kroil but I'll give it a shot when I run out of PB Blaster. I'll give the acetone/ATF solution a shot next time I have a stubborn bolt. That's an interesting approach. I was chemist for 15 years and it sounds like it would work well.
So, I didn't have any trouble pulling my original O2 sensors today (disconnecting the electrical connection was the hardest part). I sprayed them with PB Blaster Monday and let it sit until today when I gave it another squirt and then fired up the truck and drove around for 20 mins or so. I used a 10 inch cresent and they broke free with a couple of tugs.
Good luck and remember to watch out for the hot exhaust pipe.
Old Mar 4, 2010 | 10:02 AM
  #23
Sheriff420's Avatar
Sheriff420
For y'all wanting to try the atf/acetone mix, use a glass bottle to mix/store it in. Those same guys were talking about how it will eat through a plastic bottle. And wear rubber gloves and glasses, acetone is some nasty stuff.
Old Mar 4, 2010 | 03:37 PM
  #24
rideordie's Avatar
rideordie
http://www.pbblaster.com/PB_Blaster.html
PB is definitely a penetrant. I don't know if it's the best or not, but it's always done the job so whatever.
Old Mar 5, 2010 | 03:30 AM
  #25
1fast2liter's Avatar
1fast2liter
i had the same problem and after i rounded it off a buddy mentioned using a pipe wrench to get it out.. its a 22mm or 7/8" socket/wrench.. i broke the oem wrench from autozone mine was so froxe in place.. i rounded it all off trying to use a crecent.. so what did i di.. well i determinded it was in a retarded place so i bought a o2 bung for like 3 bucks from napa drilled a hole on other side of cat lenthaned the wires by about 6 inches(could have gotten the 18inch pigtail version for like 1 more) put it in pluged it in and 500 miles later not a hicup or miss yet....and went up 1mpg up to about 16.92mpg right now.
Old Mar 5, 2010 | 10:07 AM
  #26
Gary-L's Avatar
Gary-L
Veteran: Navy
Crescent wrenches are good for scrap metal. Anyone who advises someone to use a crescent wrench for any reason should be beaten with said crescent wrench.
Using a pentrant, along with heat from a propane torch, will aid in removing the stubborn sensor. Inspect the threads on the bung to insure they aren't stripped, and if they're still good, coat the threads of the new sensor with some anti-seize.
Old Mar 5, 2010 | 12:06 PM
  #27
Sheriff420's Avatar
Sheriff420
A well made Crescent wrench is fine for something that big as long as you have it adjusted correctly.
Old Mar 5, 2010 | 12:17 PM
  #28
Gary-L's Avatar
Gary-L
Veteran: Navy
The part in bold is an oxymoron.
Old Mar 5, 2010 | 12:32 PM
  #29
1fast2liter
and were in my post did i recomend using the crecent wrench.. i used it cause it was big and the o2 is in a dumb place.. and yes it rounded it off to.. a pipe wrench would have been the ticket but i dont have one... so i drilled a whole welded on a new bung screwed it in and been running great ever since.
Old Mar 5, 2010 | 01:55 PM
  #30
99redram318's Avatar
99redram318
Just take my word on this one. Use Coca-Cola to penetrate the rust. Its a trick an old Audi tech taught me when I was young. After it works it kinda freaks you out that you drink that stuff. It has not let me down since. Used it on an o2 sensor in my old stratus came right out. and just about anyother stuck on/ rusted on parts
