water pump for 1996 Ram
Old Mar 3, 2010 | 11:58 AM
Tracya's Avatar
Tracya
Default water pump for 1996 Ram
I am getting a rebuilt water pump for my 1996 Ram 5.9 and how can I tell if it needs a threaded or non threaded .
Thanks
Old Mar 3, 2010 | 12:08 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. Check out the Ram sections,
FF
Old Mar 3, 2010 | 12:15 PM
Midnight Runner's Avatar
Midnight Runner
Welcome to D.Forum.
Old Mar 3, 2010 | 03:32 PM
lblair04's Avatar
lblair04
Look at your current waterpump, and if your fan has a big nut that attaches it to the pump, you need a threaded. If the fan is held on by 3 bolts (?) then you need non threaded. This is the only thing I can think of on a threaded vs non threaded waterpump. Hope this helps!
Old Mar 3, 2010 | 03:37 PM
Gerehead8's Avatar
Gerehead8
I thought all the fans were a threaded attachment. When I got my pump they asked bolt on pulley (4 bolts) or press on pulley. I had a bolt on but bought a press on because it was cheaper and I got a new pulley.
Old Mar 3, 2010 | 09:19 PM
dhvaughan's Avatar
dhvaughan
i think all the 2nd gen magnum water pumps are threaded. you'd have to go way back to an old 1st gen/LA engine to find a bolt on fan. i'd also guess those old models are not interchangeable to the magnum. you may not be in the right year section of the parts lookup.
Old Mar 3, 2010 | 10:31 PM
highlander73's Avatar
highlander73
I believe threaded or non-threaded is referring to the pulley - does it have bolts that hold it on or is it pressed on. All fans are threaded on. I had a bolt-on pulley and when I bought my threaded water pump from Rock Auto it was the correct part. I'm guessing you are looking at Rock Auto and see the same thing.
Old Mar 3, 2010 | 10:49 PM
lblair04's Avatar
lblair04
Gotcha, my bad...learn something new every day!
Old Mar 4, 2010 | 02:34 AM
yakkier's Avatar
yakkier
1st gen has the bolts, 2nd gen and on is threaded.
Old Mar 4, 2010 | 06:33 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Not true, 96 could have either one. IIRC in 99 or 2000 they went to press on only.
