Is this Oil PSI OK?
The motor is not making any sounds, runs great, plenty of power he says...he roasted the tires when he left the house with no problems.
And whats weird is that if you let it idle for a while the pressure will slowly build up to about 35, then it will idle there but if you hit the gas pressure goes to 40, but then drops back to about 15-20...then if you let it idle it slowly builds up again and so on....since its at 40 whenever he is on the gas he should be alright for the next month....its never had that low of pressure BTW
