who thinks my ujoint is bad?? lol (video inside)
Old Mar 5, 2010 | 04:09 PM
lord0fsal3m's Avatar
lord0fsal3m
Default who thinks my ujoint is bad?? lol (video inside)
this is my front passenger side ujoint, i think it might be bad... lol.
http://www.youtube.com/watch?v=_CfLDb1QDb0
how safe is it to drive on this? ill replace it asap but i have a class 45mi away on sunday that i need to get to. what could happen if i fails more?
Old Mar 5, 2010 | 04:11 PM
xxxcowxboyxxx's Avatar
xxxcowxboyxxx
if it fails all the wy or breaks you will not be able to drive it......at least not without ****** something up bad my suggestion is if you MUST drive it....be easy on the throttle and watch the sharp turning
Old Mar 5, 2010 | 04:12 PM
yakkier's Avatar
yakkier
Stay outta 4x4
Old Mar 5, 2010 | 04:52 PM
95RAM360's Avatar
95RAM360
if that comes apart, the axle shaft will be free and could destroy some teeth in the differential.....
Old Mar 5, 2010 | 05:01 PM
xxxcowxboyxxx
personally i wouldnt chance it, i would fix it before driving it
Old Mar 5, 2010 | 05:56 PM
Synister1's Avatar
Synister1
Fix it, a new u-joint is $12 which is cheaper then replacing the shaft after you trash the yoke.
You should also replace the one on the other side since that ones toast. The other side isn't going to be that far behind it in wear.
Old Mar 5, 2010 | 06:03 PM
Dixie Mudslinger's Avatar
Dixie Mudslinger
mine failed on the same side and it was a pain to get the spindle nut off even with an impact wrench >.< but after that it was pretty much smooth sailing
Old Mar 5, 2010 | 06:04 PM
95RAM360's Avatar
95RAM360
^yup i just bought 2 for the front and it was 25 and change for both u-joints
I use a 3/4in breaker bar with 2 1/2 of 1 in piping as a leverage bar...standing on that, mine hub nut cracked free no problem...as to when i tried with a 1/2 in breaker bar i snapped it in half.....
Old Mar 5, 2010 | 07:14 PM
DukesOfHazzard's Avatar
DukesOfHazzard
I DROVE LIKE THAT ON BORROWED TIME, MY AXLE NUT WAS THE ONLY THING HOLDING EVERYTHING TOGEATHER, DO WHAT YOU GOTTA DO ASAP, OR IT MIGHT BE MORE DAMAGE DOWN THE ROAD, I REPLACED HUB AND BEARINGS ALONG WITH U JOINTS UPGRADED STOCK SPICER #...
Old Mar 5, 2010 | 08:00 PM
halfamil's Avatar
halfamil
I've never seen one that bad, that's still together. The seal is gone also ,with that much play.
