Plenum gasket change hughes, how hard is this too do?
Old Mar 9, 2010 | 04:30 PM
  #21
HDRAMman's Avatar
HDRAMman
I know I need to get mine done and really don't want to pay to have it done, kinda in the same boat as you. Wondering if I will mess something up or forget to put something back. I will tear into a rear end or swap an engine or work on any type of ATV for hours but tearing the top off my engine for my everyday truck has got me nervous.
Old Mar 9, 2010 | 04:37 PM
  #22
PurplDodge's Avatar
PurplDodge
Originally Posted by HDRAMman
I know I need to get mine done and really don't want to pay to have it done, kinda in the same boat as you. Wondering if I will mess something up or forget to put something back. I will tear into a rear end or swap an engine or work on any type of ATV for hours but tearin the top off my engine for my everyday truck has go me nervous.
If you could re-build a rear-end, the plenum gasket should be a breeze. Just take your time, there is no need to be intimidated.
Old Mar 9, 2010 | 05:48 PM
  #23
lblair04's Avatar
lblair04
Make sure while the intake mani is off to try and get all the pieces of gasket that might be laying in the valley. I took a shop vac to mine. Also, when you scrape the gasket area...cover up the valley so everything doesnt fall in (cardboard box cut up with some rags along the sides works well!)
Old Mar 9, 2010 | 07:34 PM
  #24
dhvaughan's Avatar
dhvaughan
i did mine with just a standard foot pound torque wrench, and not an inch pound. just convert the numbers. 12 in lbs = 1 ft lb.
the plenum plate is something like 72 in lb which is just 6 ft lb.
Old Mar 9, 2010 | 08:00 PM
  #25
95RAM360's Avatar
95RAM360
ok once again THE PLENUM IS NOT A HARD JOB lol.....do it yourself, you can have it done in a day
Old Mar 10, 2010 | 09:38 AM
  #26
sungod's Avatar
sungod
Once you get the fan off it is a breeze. Make sure you have the right tools to remove it or you will waste hours. You will find that you use a 1/2 and a 9/16 wrench pretty much exclusively.
Old Mar 10, 2010 | 10:29 AM
  #27
shadowdiver's Avatar
shadowdiver
I went and bought an intake from the parts yard and had a buddy of mine make an aluminum plate for mine, but after i cut the runners and ported it. Spent the weekend and welded it to the intake. Never leaked again!
Old Mar 10, 2010 | 03:21 PM
  #28
jasonw's Avatar
jasonw
Site Moderator
Originally Posted by CSXfan
Are you SURE your plenum is blown? Your mileage seems a little low for this to occure.
Mine was blown at 49,000 miles when I bought the truck.
