A question about the V8 radiators
Old Mar 10, 2010 | 10:43 PM
junkyardjeff's Avatar
junkyardjeff
Default A question about the V8 radiators
My girlfriends 98 with a 360 needs a radiator and all I can find used are ones for a 318 so will it work or should I find one for a 360.
Old Mar 11, 2010 | 02:38 AM
dakotas ram's Avatar
dakotas ram
yeah, itll work. fyi, you can get a new one on ebay for alittle over $100
Old Mar 11, 2010 | 06:34 AM
M.A.'s Avatar
M.A.
Radiator reservoir has a leak at the neck, I am planning on getting a new reservoir, What type of fluid do I need to use. I was told that the old type of green anti-freeze was not compatible with these motors, ram 1500 4.7? … Help
Old Mar 11, 2010 | 06:38 AM
PurplDodge's Avatar
PurplDodge
Ethylene Glycol is what nearly every vehicle on this planet uses.
Old Mar 11, 2010 | 08:47 AM
junkyardjeff
I thought about buying one off ebay but I heard some horror stories on another forum and would rather buy one locally if a problem would arise.
Old Mar 11, 2010 | 08:49 AM
95RAM360's Avatar
95RAM360
i dont know if you have one around you, but 1-800-Radiator is who i used when i did the radiator in my 4x4 Nissan (I know its not a ram) but that was 108 bucks.
And the parts for 318-360 are 90% interchangable...
Old Mar 11, 2010 | 11:21 PM
jswain's Avatar
jswain
318 and 360 are the same. My truck originally had the towing package, the radiator had a fin type trans cooler in it. I could not find one like it, I put a rad off a 318 on it. It had a tube type trans cooler in it. I had to extend my trans cooler return line a bit, but everything else bolted up and it works great.
Old Mar 12, 2010 | 08:57 AM
95RAM360's Avatar
95RAM360
the difference between them is 318 is internally balanced, 360 is external, and then, obvious the 360 is a bigger CI motor, other than that they are about the same.
