Which transmission solenoid
Old Mar 12, 2010 | 01:38 PM
artiep's Avatar
artiep
Default Which transmission solenoid
I believe I am going to need a new transmission solenoid in my 1998 Dodge 1500 4x4 318engine . When I look the part up online there are a few different choices of solenoids. How do I know which one fits my tranny, do I have to drop the pan to ID it, or is another way. I am not sure of which transmission I have, I was under the assumption that it was the 46re, now I am not sure
Thanks
Old Mar 12, 2010 | 02:32 PM
xray99's Avatar
xray99
Take a look here
https://dodgeforum.com/forum/2nd-gen...d-install.html
Is it throwing codes, what makes you think you need new sensors ?
Old Mar 12, 2010 | 02:44 PM
J415's Avatar
J415
Do you know the name of the solenoid? Is it the trans gov solenoid or the overdrive solenoid?
Old Mar 12, 2010 | 08:18 PM
95ram5.9's Avatar
95ram5.9
What is your trans doing?
Old Mar 13, 2010 | 07:11 AM
artiep's Avatar
artiep
Sorry for the lack of info. The trans will not shift into 3rd ,and at times shifts from 1st to 2nd at differemt rpms. I do not have any codes as of now. I would like to order the parts online but am unsure of which part I need. Different looking selonoids come up for my year truck.
Old Mar 13, 2010 | 02:40 PM
xray99's Avatar
xray99
Is your fluid level Ok ?
I'd be hard pressed to recommend a swap without codes, then again its a fairly simple procedure and not too expensive.
These here are what you want, if in fact thats the problem http://tinyurl.com/yzr9tt2
Old Mar 15, 2010 | 11:23 AM
artiep's Avatar
artiep
Thanks for the help.
Old Mar 15, 2010 | 11:41 AM
zman17's Avatar
zman17
Retired Moderator - RIP
It may very well be that the parts are the same, but the link you posted is for parts on a 42 and 44RE, not specifically for a 46RE.
