all or nothing took the plunge
Old Mar 27, 2010 | 09:27 PM
  #21
yakkier's Avatar
yakkier
You're thinkin of the crank sensor or cam position sensor or something along those lines
Old Mar 27, 2010 | 10:10 PM
  #22
xjarhead69's Avatar
xjarhead69
Originally Posted by 95RAM360
i cant remember which one it is, but you didnt pinch on of the sensors between the tranny and motor did you? i ve heard of problems like this, and it turned out to be a pinched wire between the tranny and motor
That would be the crank sensor. That is why I replaced mine. It got pinched in there when we replaced the tranny.
Dave
Old Mar 28, 2010 | 10:27 AM
  #23
Rams3's Avatar
Rams3
ok so if truck been sitting more than ten minutes or so even if i turn key on and off a few times letting pump build pressure still does not help must give it gas to start, but this morning after truck sat for about 12 hours it fired right up? then drove to coffee shop truck was off about ten min or so and there we go again cranking untill i give it gas?? as far as pinching wires i doubt it but anything possible when we pulled engine and tranny as one i had everything disconnected and harness up against windshield we bolted engine, tranny, and transfer case back togeather outside the truck and put in as one??
Old Mar 28, 2010 | 12:34 PM
  #24
xjarhead69's Avatar
xjarhead69
If you assembled everything out side the truck then I don’t se how you could have got the wires pinched. One thing I can thank of. On the driver side the harness on mine was anchored at the bell housing because it ran very, very close to the exhaust manifold. Was yours anchored this way and was it put back and anchored to the bell houseing? Cooked wires maybe?
Dave
Old Mar 28, 2010 | 02:17 PM
  #25
Rams3's Avatar
Rams3
Ya wires were close but I reinstalled them all up and out of the way, I am an electrician and I am very **** about the wires I disconected and reconected all wiring, all connections were cleaned and dielectric grease on all .....
Old Mar 28, 2010 | 05:25 PM
  #26
Rams3's Avatar
Rams3
ok so i put a fuel gauge on fuel rail port to see if possibly fuel pump going bad or new fuel injectors no good, so i was loosing pressure, hmmmm. I pulled the injectors out still attached to the rail turned key on and what do you know gas coming out of three of the injectors, so i installed the old ones with 100k on them and what do you know problem solved. By the way i had purchased the brand new injectors from advance auto they were bwd injectors, now im not sure if im going to just run the old ones or get new from dodge? I am going to go return these pos to advanced.
Old Mar 28, 2010 | 06:36 PM
  #27
yakkier's Avatar
yakkier
glad you got it figured out, now post some damn pic's and fill out your profile information already
Old Mar 28, 2010 | 06:51 PM
  #28
CPTAFW163's Avatar
CPTAFW163
Get these injectors. I have these, and they were GREAT. Once my 2001 is void of the warranty, i will be putting these on:
http://www.fiveomotorsport.com/domes...rs/?itemid=297
It does not say a price, but they are 385 for a set of 8. Call Bruce. he threw in a set of EV1 connectors for free with me. YOu will need the new connectors to ensure a tight fit. The stock ones i had fit on there, but were loose. The reason they were loose was because the thin metal clips were gone and they were not holding the connection tight. SO get new connectors.
You can see pics of these in my profile album. Since our trucks run at 49PSI (haynes says 43.5, but i have always read 49 from my gauge in my 1996 and 2001) you will have some room for mods (1.7s, throttle body, F1 airgap) since it will run 25.5 lb/hr. Plus the 4 hole design makes for much better efficiency and power.
Stockers are 22lb/hr.
