Front end malfuction
Old Mar 15, 2010 | 10:10 PM
xray99's Avatar
xray99
Default Front end malfuction
Was driving down the road today about 35 mph, all of the sudden it felt just like I had a front tire blowout.
I coasted into a gas station expecting to see a blown tire, but the tires were all fine. Did a quick check under the vehicle, nothing looked amiss.
Something was wrong obviously, you just don't get that blowout feeling for nothing, so I decided to try to limp home.
Truck rolled, but over 25 mph it started vibrating something awful, so I limped home, about 4 miles away, at 20 mph.
It was getting close to dark, I put the truck on a cement pad to jack it up.
Looked again underneath with a spotlight, still couldn't see what the problem was.
Jacked it up and got one tire off, the passenger side tire a lug is seized on the bolt. I had the feeling I was about to twist the bolt off, which is what I'll probably have to do tomorrow to get it off.
So as of now, its a mystery what went wrong. Nothing obvious like a broken coil, floating tierod or busted shock ,,, I'm doubting if it was ball joints. Put new ones in about a year ago, and if I busted a ball joint I doubt if I'd have been able to limp anywhere at any speed.
So I'll post back tomorrow when I get a chance to look at it, anyone want to take any lucky guesses in the mean time, feel free.
Old Mar 15, 2010 | 10:23 PM
dhvaughan's Avatar
dhvaughan
i'll guess axle u-joint.
Old Mar 16, 2010 | 01:34 AM
Miami_Son's Avatar
Miami_Son
Great thread title!
Old Mar 16, 2010 | 02:29 AM
Sheriff420's Avatar
Sheriff420
I would guess wheel bearing or a control arm is busted. Isn't your truck 2wd?
Old Mar 16, 2010 | 05:53 AM
xray99's Avatar
xray99
Yessiree, 2WD.
All guesses sound perfectly feasible so far, hopefully will know the cause early this evening after work.
Actually I have been noticing a progressively worse front end vibration for quite some time, only between 25 and 30 mph, so chances are whatever failed has been trying to warn me for months.
Lazy *** me let it slide, I was thinking it was a busted tire belt, and was about to get a new set when my taxes came in.
Old Mar 16, 2010 | 06:59 AM
95RAM360's Avatar
95RAM360
Id say this sounds like the "Death Wobble"......hows the trac bar?
Old Mar 16, 2010 | 07:26 AM
xray99's Avatar
xray99
Dunno about the trac - I thought the wobble was pretty much limited to HD, lifted and trucks with oversized tires ?
Old Mar 16, 2010 | 07:32 AM
95RAM360's Avatar
95RAM360
...when i searched it on youtube, it was showing stock vehicles with the deathwobble
Old Mar 16, 2010 | 08:23 AM
Sheriff420's Avatar
Sheriff420
I thought track bars were only on 4x4 trucks.
Old Mar 16, 2010 | 10:42 AM
dodgeboy1979's Avatar
dodgeboy1979
Separated tire?
