Help with front bearing removal!
Old Mar 17, 2010 | 04:26 PM
95ram5.9's Avatar
95ram5.9
Default Help with front bearing removal!
Can someone please tell me how to get the other half of the wheel bearing off please. All 3 bolts are removed and it wont budge!
Old Mar 17, 2010 | 04:38 PM
sit22 II's Avatar
sit22 II
If you have an air chisel and extra bolts you can
put the old bolts 1/2 way back in and with the air chisel just chisel the bolts heads to push the bearing out.
or..
put the bolts 1/2 way back in and start the truck and turn the steering slowly till the bolts hit and push it out that way ( havent tried this but read it here)
Old Mar 17, 2010 | 05:13 PM
95ram5.9's Avatar
95ram5.9
Using an air chisel do you mean using it like a wedge between the bolt head and knuckle to drive it out?
Old Mar 17, 2010 | 05:23 PM
Sheriff420's Avatar
Sheriff420
He means to put the air chisel on the head of the extra bolts and drive them toward the bearing.
You'll want the bolts threaded into the bearing a few threads but have them at least 1/2" from touching.
Just use plenty of penetrating fluid.
Old Mar 17, 2010 | 05:27 PM
yakkier's Avatar
yakkier
i just did this a couple days ago, my thread is still alive. I used a catclaw side of a crowbar and a hammer. took a few good hit's and it poped out, also helps if you soak it down in some liquid wrench or PB blaster and let it sit for a hour or so.
Edit: nvm i dont think that'll help you.
Old Mar 17, 2010 | 05:35 PM
95ram5.9's Avatar
95ram5.9
Thanks for the help guys! Will try the prybar first since I have no extra bolts on hand.
One more question... Once I get the bearing off will the axle slide right out? I need to replace the u-joints as well. Thanks again for the help!!!
Old Mar 17, 2010 | 05:39 PM
yakkier's Avatar
yakkier
yep, theres ALOT of pics in there, some on the first page and alot towards the end. https://dodgeforum.com/forum/2nd-gen...-tomorrow.html
Old Mar 17, 2010 | 07:44 PM
dhvaughan's Avatar
dhvaughan
yes. you have 2 sticky points holding the bearing (or bearing half) in the knuckle. the inner part of the hub is splined, so it can be all rusty on the axle. you might have already split this half off. the outer part of the bearing is in the knuckle, and it can be all rusty as well.
once you get the hub out of the knuckle, the axle will sort of fall out.
before you do anything else, you want to stop and think about your delicate little axle seals that live at the pumpkin. as soon as your axle end comes loose, you want to be very GENTLE sliding those sharp, dirty, heavy axles in/out of those delicate rubber seals. f*** them up and you'll be doing it again to replace the seals.
even now, if your axle is flopping around - stop and secure it so its not f***ing up those seals.
Old Mar 17, 2010 | 09:48 PM
95ram5.9's Avatar
95ram5.9
Unhappy
I did already split the bearing, I beat on the rotor with the sledge hammer for a good hour and a half before it finally came off. This $15 u-joint replacement is getting expensive real quick
