Weird rattle in dash
like i said in the title i have a weird rattle that sounds like its comeing from inside my dash it only does this tho around 1800 rpm any ideas on what this could be??
it looks like this, with only the white part sticking out. Look on the passenger side valve cover, it'll have a hose connected to it. Listen to it and feel it while the truck is running. Maybe rev the truck up a little too.... it might not be your rattle, but it fixed mine...
Trending Topics
Does it do it more when the engine is under load (ie going up a hill or passing someone)? Are you burning oil? I'm betting on the plenum gasket or a vacuum leak. I had a leaky plenum, craked vacuum lines and a couple of bad vacuum check valves. When I would give it the gas going up a hill, the valves clattered and the AC quit blowing. It also was burning a lot of oil and the hubs had trouble unlocking. But, it was pretty clear the clatter was going from the engine and not the dash.
Like they said, take the air cleaner off and look into the throttle body with a flash light and check for oil and goo. If that's not the plenum (and even if it is) check the vacuum lines coming off the manifold to make sure they aren't cracked.
