Removing fuel injectors
Did my search of the forums which usually answers most of my questions. Just could not find a real detailed DIY.
I want to remove and clean the fuel injectors (stock 5.2L). Looking things over I can see where the fuel rail is bolted down. Once the bolts are removedif I gently lift up will all 4 injectors come out with it? Or do I need to disconnect each injector from the rail working my way from one end to the other?
Thanks!
Thanks!
you need a disconnect tool to remove the fuel line from the rails, from there, you should be able to remove injectors and rail together. be sure to get new orings and lightly lube them with oil before reinstall. the injectors just clip onto the rail
Trending Topics
