Can't get diff cover off
Old Mar 19, 2010 | 09:51 PM
CPTAFW163's Avatar
CPTAFW163
Default Can't get diff cover off
ALright, the last time the diff fluid was changed in this truck, the person that did it used half the RTV sealant in the world. I took off the bolts and it will not BUDGE. Anyone know of a tool to use.
I have tried beating the crap out of it with a rubber mallet, wedging a screwdriver in the sides, and even tried prying it gently in the fluid level hole.
Is there anything else? I already siphoned the fluids out thru the hole, i am thinking of just using the hand pump to put the fresh fluids in and call it a day. But I want to clean the inside of the diff cover,m inspect and paint the diff cover.
--Dan
P.S. I am using 100% Lucas oil additive in the diff. It said it can be used 100% and will not void the warranty...and it also does not need the limited slip additive. Anyone else try that?
Old Mar 19, 2010 | 09:54 PM
xxxcowxboyxxx's Avatar
xxxcowxboyxxx
yeah use a screwdriver and hammer dont be afraid it will come
Old Mar 19, 2010 | 09:58 PM
mr freeze's Avatar
mr freeze
Stick your finger in the hole and pull real hard?
Old Mar 19, 2010 | 09:59 PM
CPTAFW163's Avatar
CPTAFW163
I was using a screwdriver and rubber mallett. I will use the hammer. I was getting impatient ebcause i wanted to do this with about an hour of daylight left.
I will get it done tomorrow. It is just a slap in the face when something so simple makes for a timely consuming job.
THANKS!!!
Old Mar 19, 2010 | 10:03 PM
xxxcowxboyxxx
even if you have to get a slot cut in it with a screwdriver or something, then use a hacksaw blade to go the rest of the way around if its fighting you that awful bad. i would just persuade it tho....wedge a prybar or screwdriver in it and then pry back with it
