Shift kit.
Old Mar 21, 2010 | 10:39 PM
Cheat's Avatar
Cheat
Default Shift kit.
You guys think it would be ok to put a shift kit in a 46re with about 100K on the trans? Or should I just forget about it?
Thanks,
Cheat.
Old Mar 21, 2010 | 11:11 PM
dakotas ram's Avatar
dakotas ram
i put a jr shift kit in my 46rh with 120k and its been fine....if anything is gonna hurt it itll be putting fresh fluid if yours is pretty thick and old......what gears you runnin?
Old Mar 21, 2010 | 11:16 PM
Cheat's Avatar
Cheat
4:10's But also i looked on the box that my dad bought years ago its for a 46RH So now I need to get rid of it. Anyone want to buy a shift kit?
Old Mar 22, 2010 | 01:22 AM
Gerehead8's Avatar
Gerehead8
They tend to work in both as I have seen. Are you sure it won't work in the 46RE? Both the transgo and the TCI I have had said they work in both the RH and RE.
Old Mar 22, 2010 | 01:24 AM
Cheat's Avatar
Cheat
It says like 78-94 trucks 46RH and then re is listed under the slot where its a manual trans. Like you got to go 1........2..............3..................OD..... ......
I dont want that.
Old Mar 22, 2010 | 01:29 AM
Gerehead8's Avatar
Gerehead8
That doesn't make a bit of sense on why it would do auto in the 46RH and would be full manual in the 46RE but who knows. What brand is it?
Old Mar 22, 2010 | 01:31 AM
DukesOfHazzard's Avatar
DukesOfHazzard
If it was me i would look into the SURE CURE KIT from Sonnax, It adresses common problems with the tranny. Better to address the probs then start new ones
Old Mar 22, 2010 | 01:34 AM
Cheat's Avatar
Cheat
Transgo TFOD-518-500-618 kit.
Old Mar 22, 2010 | 01:37 AM
Gerehead8's Avatar
Gerehead8
The sure cure fixes the problems but doesn't noticeably firm up the shifts. A shift kit will fix the problems but has a firmer shift or a really hard shift like my truck.
Old Mar 22, 2010 | 01:38 AM
J415's Avatar
J415
+1 I just installed the sure cure kit and it wasn't as hard as it's made out to be. I'm still in the process of rebuilding my tranny so I'll be sure to keep you posted.
