Any differences between a trans for a 318 and 360
Old Mar 22, 2010 | 11:34 PM
junkyardjeff's Avatar
junkyardjeff
Default Any differences between a trans for a 318 and 360
Girlfriends truck has a 360 and I might have found a trans for a 318 so if its still available will it work and how can I tell what trans her truck has,I know what a 727 or a 904 is but the new ones got me confused.
Old Mar 22, 2010 | 11:53 PM
J415's Avatar
J415
From what I understand both engines have a 46re. I think it was the V10's and the deisels that came with different tranny's (47re 48re) Not 100% sure though.
Old Mar 23, 2010 | 12:04 AM
PurplDodge's Avatar
PurplDodge
Any 96 up 46RE will work. Make sure you get one for a 2wd, not 4wd.
This has been covered 10,000 times. Next time do a search.
Old Mar 23, 2010 | 12:07 AM
97tn4x4's Avatar
97tn4x4
Yes they are the same. Even the v8 2500's have the same tranny. From 95 to 01 they have a 46re. The 94's had the 46rh. To tell the difference in the rh and the re look at electrical plug, the re has 3 wires and the rh only has 2
Old Mar 23, 2010 | 12:22 AM
J415's Avatar
J415
If you found a 4x4 and you have a 2wd tranny, you could just use the barrel, everything but the transfer case and stick an OD tail shaft unit on there from another tranny. Just another option.
Old Mar 23, 2010 | 01:13 AM
Gerehead8's Avatar
Gerehead8
What year truck?
Old Mar 23, 2010 | 08:41 AM
junkyardjeff
She has a 98 SS/T and I found someone parting a 97 sport,I presume its a 2wd since there was no mention of a transfer case and front differential. I also found someone parting a 97 4X4 with a fresh trans but they are wanting more for it then what I can get hers gone through so I hope I hear back on the 97 2wd.
Old Mar 23, 2010 | 11:48 AM
J415's Avatar
J415
The 94-97 have and extra Vehicle speed sensor in the OD tail shaft. The 98 and up don't. Just plug that back sensor and your good.
