Up's!! And Downs!! Of a shift kit
Old May 3, 2005 | 01:55 AM
crusher135's Avatar
crusher135
Default Up's!! And Downs!! Of a shift kit
I have a 96 dodge ram 1500 5.2l 4x4 wat are the good things and the bad things about a shift kit for an auto tranny
Old May 3, 2005 | 05:22 AM
crusher135's Avatar
crusher135
Default RE: Up's!! And Downs!! Of a shift kit
damnit people i wanna know so i can buy one or not buy one :P
Old May 3, 2005 | 09:54 AM
Snafu's Avatar
Snafu
Good- Better shift response, higher line pressures, lower fluid temperature, longer trans life
Bad- Harder shifts can be annoying for some people on a daily driver
Old May 3, 2005 | 12:52 PM
whitey's Avatar
whitey
i had a shift kit in an older vehicle and under heavey throttle when it shifted it would bark the tires. but that depends on the shift kit.[sm=gears.gif]
Old May 3, 2005 | 03:21 PM
2001ramsport's Avatar
2001ramsport
just do it!!!!!!!!!!
Old May 4, 2005 | 05:34 PM
Flynbryan19's Avatar
Flynbryan19
How much do the shift kits go for?
Old May 11, 2005 | 12:26 AM
cocktail69888's Avatar
cocktail69888
go to krc performance or take out the clip on the throttle body on the passenger side. It has a white clip (pull it out) then adjust the cable towards the fire-wall to increase shift points. Remember to mark the original setting so you know where to start and I would go only one notch at a time until you get the desired effect.
Old May 11, 2005 | 12:27 AM
cocktail69888
Oh yeah reinstall the clip to keep the TV cable from moving.
Old May 11, 2005 | 01:31 AM
Ramtuff's Avatar
Ramtuff
A shift kit has a few advantages over adjusting the TV cable...one of which is improved oiling to the overdrive unit. Since the overdrive is a common failure point for these trannys, I'd suggest installing a shift kit.
Old May 12, 2005 | 05:12 AM
BluevenomGT's Avatar
BluevenomGT
do they make a shift kit for the 2001 5.2? I was told it was just something they reprogrammed?
John
