What trannsmission is in a 1997 ram 1500? Will a 1996 work??
Old Mar 27, 2010 | 11:48 PM
xjarhead69's Avatar
xjarhead69
Originally Posted by Baxtersummer
I am having trouble finding what transmission is in my friends truck. A guy is selling a very similar donor truck with a brand new trans in it and I need to know if it will work. I looked at the trans in donor truck and it looks identical but the owner says it won't work because it has different internals?
1996 ram 1500(new trans) Manufactured 8-95
VIN 1B7HF16Y5TS512866
sticker under hood is unreadable??
1997 ram 1500(truck with bad trans)
Vin 1B7HF16Y3VS128104
The sticker under hood says codes: DGB standard duty 4spd auto
DGT 4spd Auto Trans CHR
DHA CC Torque Converter
If this trans wont work, I still need to know exactly what model it is to order parts or find a remanufactured one. Any help is greatly appreciated!!!! Thanks guys!!
Call Dodge dealer on Monday give the parts guy both Vin numbers and he can print off build sheets for both trucks.
At very least he can tell you what transmission is in each one.
My truck was built Oct 31-95 and has 46re in it according to build sheet.
Dave
Old Mar 28, 2010 | 12:50 AM
Baxtersummer's Avatar
Baxtersummer
Good idea Dave. I thank you very much!! Have a good one! Jeff
Old Mar 28, 2010 | 02:43 AM
Ram_Me's Avatar
Ram_Me
Just so you guys know, it's not 96.5, just 96. Both of my 96s were built in January, and they both have 46REs. Either way, I don't think it will work between different years and I don't think it's worth trying to find out.
Also Rams with the cummins have 47REs not 46REs.
Old Mar 28, 2010 | 06:40 PM
jasonw's Avatar
jasonw
Site Moderator
V6 2WD = 42RH
V6 4WD = 46RH (I have not verified this.)
V8 = 46RH
V10 or Cummins = 47RH
1996-2001:
V6 2WD = 42RE
V6 4WD = 46RE (I have not verified this.)
V8 = 46RE
V10 or Cummins = 47RE
Those apply to both 1500s and 2500s.
Plus, as others mentioned, there are electrical differences from year to year. Not sure what years are compatible with each other.
Old Mar 28, 2010 | 10:02 PM
bigmanram's Avatar
bigmanram
I ran into this problem a few months ago when i replaced the transmission in my 97 4x4. When i started looking around i was told numerous times that only a 97 model transmission would work in a 97 model truck (i was told this by all of my local transmission shops and junkyards). I was told that there was differences in the internal electronics between 97 and later year transmission. i luckily found a rebuilt 97 model transmission for mine , but it is something to consider.
