Replaced the MAP Sensor
Old Mar 27, 2010 | 11:53 PM
jamesnb's Avatar
jamesnb
Default Replaced the MAP Sensor
So I replaced the MAP sensor on the 2001, 1500 Ram 4x4 "Off Road" edition, 5.9L engine. I've been replacing things and I fifured since the Throttle Body looked like it fell in an asphalt pit, it couldn't hurt. As it turns out, it probablly didn't need replacing. Even ten years old and after 174K miles and the gunked up TB, the membrane was in good shape and the inlet port and hose were clean.
The new part was $62 ordered through AutohauseAZ (I order a lot of parts for my Mercedes through them). It was easy to install. There are two Torex head screws holding it on and a tiny hose. Even if you aren't planning to replace it, it's worth it to pull the unit to check to be sure the hose is in good shape and not leaking.
I have pictures, but they are crappy cell phone pictures.
The nipple that connects to the manifold:
MAP cut open, showing the curcuit board:
Curuit board lifted to show the pressure sensor on the back of the board. Still soft and pliable:
Hole in the housing that the pressure senor sits on. The other side has the nipple that connects to the manifold:
Old Mar 28, 2010 | 12:44 AM
dakotas ram's Avatar
dakotas ram
hmmmm, interesting
Old Mar 28, 2010 | 01:33 AM
yakkier's Avatar
yakkier
Pictures are kinda blurry but i get the general idea, thanks!
Old Mar 28, 2010 | 02:40 AM
Maxx_Magnum's Avatar
Maxx_Magnum
nice to see someone take the time to take that apart and post some pics up
